Kef THX 45B distorting / interferance / feedback
Discussion in 'Home Cinema Buying & Building' started by DTNS666, Feb 21, 2014.
  1. DTNS666
    DTNS666
    Feb 21, 2014
    Hi I have a KEF TDM 45B subwoofer I have had it for approx 15years been fine (apart from the 1st time it went wrong and it was repaired under warranty).
    How ever i think the same error has come back it is a bit hard to explain, effectively it distorts when no sound is been play through, and it also distorts / thumping feedback (with no input cable in)when you press the THX button on the back. Pretty sure this is the same faulty as before, does any one know where i can get it repaired, or any idea what it is.
    I read somewhere a while ago it was a common fault with it but i cannot remember where i saw that.
    circuit boards are indigo LCBASH Linear PCB as per images,
    Any help would be great or any recommendation what to replace it with these days
