Also reading that even Kef claimed a frequency cut off point of 35Hz, it doesn't exactly bode well for a beast of a sub.
Am i remembering correctly that THX subs have to reach 20Hz? The 45b was the first real sub i owned, and i never had any problems with it at all. It played low, to the point of helping out my Kef 4.2's at the time, and never struggled. Given that this sub was designed about 15 years ago during the Dolby Surround days, it's not quite as bad as people seem to remember.
I'm not one to purely go by specs. I'm a follower of the saying "if it looks right, it is right", and i think that can be used for audio by changing it to "if it sounds right, it is right". Just listen to a Rega system to understand what i mean.
Helicon have you heard a Monolith?
Only at the Bristol show. But after 18 years in this industry i'm aware of what manufacturers can achieve for given price points. Occassionally the bar is pushed a little, but never so far from everyone elses reach that it's out of focus. For £400, there's only so much R&D and materials you can afford, and there's two ways to make a sub at that price. Small, tight, agile, but lacking in ultimate power and extension, or build bigger using cheaper parts, but has drawbacks on the control and quality front. I'm not saying the monolith isn't any good, just that it's built to a budget. If you build to a budget, compromises have to be made somewhere. I'm sure you can appreciate what i'm saying if you compare a pair of Dynaudio 42's to a pair of Mission 7351's.
Why do you need big amps to drive subs ? The strata was only 60 watt, but a lot smaller driver, same with storm small driver only 100 watts, but the kef had 15 inch driver but big amp ? is it size of driver, but the Rels are ported ? which is best small amp small driver but ported or big amp , big driver but sealed ?
There are no rules. Sub bass is all about shifting air, for which you need a large bass driver. To keep that hefty thing responsive and under control, you need a powerful and amplifier. All this needs a sturdy cabinet and a lot of R&D to work well together. I personally feel sealed cabinets sound tighter and have less drawbacks, but that usually upsets owners subs of the ported persuasion......
