KEF Subwoofer Problem. Help is appreciated
Discussion in 'Subwoofers' started by jdecaro, Sep 14, 2003.
  1. jdecaro
    jdecaro
    I have a 5 +1 KEF (eggs) system installed, which was working fine until recently. I realized yesterday there was not bass sound coming from the subwoofer. I remember that a couple of weeks ago I installed an HD cable TV receiver (motorola) which would give a buzzing noise to my subwoofer even if it was not turned on (it would be plugged in). After being annonyed by this sound , I disconnected the HD receiver. Now at the back of the subwoofer , there is an LED. I remeber this used to be red when the subwoofer had sound. Now as soon as I turn the subwoofer on, and I switch the receiver on , the light becomes green and no sound of course. I have used the receiver's (Denon) testing thing to direct sound only to the subwoofer and there is no sound. I tried plugging the subwoofer directly to the SW output of my DVD player and still there is no sound (this is why I believe there is something going on with the woofer instead of my receiver). What puzzles me is that LED that stays green. I would appreciate any input. Thanks. J
  2. rauer
    rauer
    Feb 17, 2001
    425
    +7
    Actually I think you've mixed up the LED colours. It's red when it's in stand-by mode and green when it's receiving a signal.
    That how it's on my PSW2000 anyway.
  3. jdecaro
    jdecaro
    So does this mean , that I do have a signal in the subwoofer?
    Then, is the actual speaker damaged?
  4. rauer
    rauer
    Feb 17, 2001
    425
    +7
    I'm no expert but that could be the case.
    A silly question: you haven't accidentally turned down the volume on the sub, have you?
  5. jdecaro
    jdecaro
    I do not think so. I have 3 knobs on the back. I have been playing with all of these to no avail. Unless there is another knob somewhere that I do not know about (which may be very possible)...
  6. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    Hi there, what has happened is that the internal amp has blown. So although your sub is receiving and detecting a signal the actual amp inside that drive the cone has ceased to function. This is a common fault with the Kef subs and your local dealer should be able to get Kef to send them a replacement amp and they can fit it in the store, providing it is all under warranty of course. I know this beacause I am a Kef dealer.
  7. jdecaro
    jdecaro
    It should be under warranty because I bought it from a dealer , less than a year ago. I guess I wil have to find the receipts..
    Thank you!
  8. tmurphy
    tmurphy
    Mar 5, 2003
    560
    Preston
    +60
    Had had a sililar problem with my sub from my 2005.2 setup, but instead of no sound, it kept buzzing VERY loudly even when there was no sound source linked up to it.
    I took it back to Practical HiFi in Preston and they hooked it up there and it did exactly the same thing they diagnosed it as a faulty amplifier module, but what I did hear was the owner talking to one of the staff saying somthing along the lines of "Just swap it out for one of the new batch and send the faulty unit back along with the others".
    Have KEF had a bad batch of amplifiers?
    My replacement even seems to sound better than the previous unit, but it might just be my imagination!
  9. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    This is a little worrying as I'm due to get a set of 2005.2's on Saturday.
    The comment of 'this is a common fault' hasn't inspired much confidence either.
    I was reading a fair bit about speakers before deciding on the Eggs, and this is the first I've heard about this problem.
    So either it isn't very common, or the people it has affected haven't posted here about it.
  10. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    As far as I'm aware and have experienced so far the problem was only with the older Mk 1 package and the PSW 2000 that came with it. As yet I have had no problems with any of the subs that come with the KEF 2005 Mk 2 package. THe problem is not that frequent it's just that when I do see these subs come back into the store it always the same fault. I would not let this put you off the Mk 2 Kef eggs as it is a fabulous package for the money and a huge improvement on its predecessor. I hope this is of some use to you.
  11. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    *phew* wipes forehead in relief :)
  12. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hi there all, the same thing has just happened with my kef 2005.1 sub. I got mine almost 3 years ago though. Doesn't anyone know how much these are to fix?
    thanks
    Cameron
