KEF Speakers
Discussion in 'AV Receivers & Amplifiers' started by zippo4, Oct 30, 2001.
  1. zippo4
    zippo4
    Oct 28, 2001
    Kent
    Just about to stick my toe in the Home Cinema waters with the following setup (I think!)
    Denon AVR 3802
    Denon DVD2800
    and ? speakers? I was considering KEFs as they seem to be pretty well made, had good reviews and small enough to keep my girlfriend quiet :rolleyes:
    Any comments/advice on the above much appreciated, particularly the speakers. And does anyone know a good place to buy online, so far unbeatable.co.uk has come up with the best prices.
    Paul
  2. elaysian
    elaysian
    zippo4,
    I have the setup you are thinking of, except I have the 3801, and can thoroughly recommend it.
    It sounds so sweet and powerful, with both music and movies.
    You will not regret it.
    Jon
  3. steve k
    steve k
    Apr 15, 2001
    713
    Birmingham
    +53
    Have just listend to this set up today at Seven Oaks in birminghm.
    The sound from the speakers was brilliant considering how small they are.
    The guy in the shop suggested i listen to the Onkyo av Tx-DS696 which is the same price ase the Dennon only has 5.1 but more power, 5 x 130 have not read any write ups on this amp if any one has let me know.
  4. zippo4
    zippo4
    Oct 28, 2001
    Kent
    ...for the feedback. Just have to convince the girlfriend now!
    Zippo4
  5. Silver
    Silver
    check out richer sounds, they're selling the kef crestas 1,2,3 & centre pretty cheaply £59-£89-£119-£59 respectively
  6. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    The Denons deserve better than Crestas. I use the Denon 3300 with Kef Q55.2 / 95.2 C and they work well for movies and music. if you like rock music or dance music you may find the combination a bit too civilised.
  7. Lowrider
    Lowrider
    If you buying the KEF eggs, get the 3802 or another receiver with variable crossover frequency, as they don´t really go down to 80 hz...
