kef speakers
Discussion in 'Home Cinema Speakers' started by phill147, Sep 7, 2012.
  1. phill147
    phill147
    Mar 15, 2010
    25
    what are kef 2005.2 speakers like are they worth getting
  2. sergiup
    sergiup
    Apr 29, 2008
    7,748
    SE London
    +4,137
    They're good, and possibly depending on your requirements, budget, etc.
    If you give us more details we can give you a better answer..
  3. phill147
    phill147
    Mar 15, 2010
    25
    i have 250 300 to spend at min stuck between satelite 5.1 system or go for bigger seperates seen some good offers on wharfedale and q acoustics speakers but the main sub seems to be the most exspensive seperate unless you get a package what would be good for just movies
    what would be good for both movies and music
    would i be better geting older equipment for money
    running yamaha v671 amp so these options are below par for amp but im not that rich yet but need a half decent setup till more funds avalible
  4. greeng4309
    greeng4309
    Nov 29, 2007
    164
    +13
    I've got a bit of experience with the Kef eggs. Currently on my fourth different version.
    2005.2's are good for movies but okay for music. If you can stretch your budget, aim for the 2005.3. Different design tweeter and far superior sounding. Dialogue cleaner and clearer and pretty good for music and Kube 2 sub is pretty strong as well.
    Obvious limitations with music due to egg design, but unless you pump dance tunes at max all the time the eggs will serve you well.
