Kef Reference One
Discussion in 'Home Cinema Speakers' started by ilkand, Jun 12, 2002.
  1. ilkand
    ilkand
    Feb 9, 2002
    404
    +3
    Please can someone tell me if the kef reference ones have one of those boundary compensation devices fitted. Just bought some and was expecting to find one but cannot, although do not really know where to look. They are 1's not 1.2's (if you see what I mean).
    Andy
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    If they have a BCD its inside the speaker terminal, its a small grub screw that you unscrew and turn over and screw back into place again depending on which setting you want. Its in the positive terminal if I remember rightly, you have to unscrew part of the binding post first of all to get to it (the bit the banana plug goes into).
  3. ilkand
    ilkand
    Feb 9, 2002
    404
    +3
    Thanks for the info.
    Had a look for it, but does not seem to be there. Must just be on later models.
    Andy
  4. Ten
    Ten
    Jul 1, 2001
    163
    16
    UK
    hiya
    just had a look at the instruction manual (gasp) :D and i'm afraid that the model ones and fours didn't have this facility.
    btw it's normally found beneath the LF+ terminal.
    ten
  5. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    Checked my model 2's and they have it. In the bottom + terminal. You can just make out a slot to put a flat head screw driver in. All the other terminals have a hole.
