I have my R300s on the Fisual Dynami Duo, which has a top plate of 200mm by 165mm (20cm by 16.5cm). Having taken a closer look just now, I think your stands will probably work fine (especially with regard to the width), but would personally prefer the slighly larger size of the Duos.Hello!
I've found some stands for sale, and am not sure if the top plate is too small?
the kef r300 dimensions are (w)210 x (d)345 mm
The stand with no name or model top plate is 17cm x 13cm
would you say this is too small for the speaker?
Feels a bit small for me, you'll have a lot of overhang front to back, with the plate only being approx 30% of the speaker area.Hello!
The atacama nexxus 600 have the option of a large top plate with dimensions 190x305mm, and also allow for additional weights for the base plate, as I was going to get them for my R3's, but ended up building my own in the end.Thanks guys, I was thinking just a tad to small too but wanted others thoughts. I'll keep looking,
I'll check out the fisual see how much they are.
they do look nice, I need min 750mm height, as they are for the rears and sofa headrests get in the way. I looked on their site and don't see other heights, as that would have been perfectThe atacama nexxus 600 have the option of a large top plate with dimensions 190x305mm, and also allow for additional weights for the base plate, as I was going to get them for my R3's, but ended up building my own in the end.
The website does say height options will be available this year, but it said that a few months ago when I started looking. Might be worth dropping them a message to see if the configurable heights are nearly available.they do look nice, I need min 750mm height, as they are for the rears and sofa headrests get in the way. I looked on their site and don't see other heights, as that would have been perfect
good idea, will give them a bell. thanks for the info so far...The website does say height options will be available this year, but it said that a few months ago when I started looking. Might be worth dropping them a message to see if the configurable heights are nearly available.
