Hello,
I’m just starting to learn about all this, reading forums, appreciate any input at all.
1. Should I set the NR1711 to 4-ohm mode, given the R3’s can dip to 3.2ohm at some frequencies? Or leave it at 8ohm / default? Will it make a difference?
2. Any point to using the unused surround channels and bi-amping the R3’s with the NR1711? On another forum, it was suggested this is in effect bi-wiring and won’t make any difference. Even though the Marantz manual calls it bi-amp mode?
- I have a Marantz NR1711 + some old DALi Concept 2 bookshelf speakers.
- Looking at upgrading those to KEF R3’s soon (and hoping for distinct difference in audio enjoyment)
- I will eventually get a seperate power amp (Peachtree?) and use the pre-out on the NR1711 to drive the R3’s.
- The NR1711 is due to space (height) constraints and I’m only using 2 fronts and a centre (maybe a sub later).
- Rarely does the volume go above 50% due to apartment living, mostly listen around the 25% level.
