Question Kef R200c on a shelf?
Discussion in 'Home Cinema Speakers' started by guest, May 8, 2018.
  1. guest
    guest
    Sep 13, 2010
    752
    46
    +164
    Can I put the Kef R200c on a floating shelf beneath the TV?
    I can see center speaker stands but I would rather it was fixed to the wall..(Kids / Dogs)
    As I like the bottom third to half of the TV at sitting eye level means the TV sits lower down. My idea is to put a floating shelf with acoustic foam with pointing slightly up...
    Does this sound like a reasonable plan?
  2. Andrew K
    Andrew K
    Oct 14, 2004
    3,392
    +608
    Yes that will be fine
  3. guest
    guest
    Sep 13, 2010
    752
    46
    +164
    Thank you
  4. Russ 66
    Russ 66
    Jan 5, 2004
    1,990
    116
    Norfolk
    +1,442
    You might need to fit the foam bung if its close to the wall.
    • Thanks Thanks x 1
    • Agree Agree x 1
    • List
  5. gibbsy
    gibbsy
    May 17, 2007
    12,337
    3
    Cwm Cynon, De Cymru
    +6,676
    Heavy old beast wall fixings need to be really secure. Try and keep the front of the speaker proud of the edge of the shelf to avoid unwanted sonic reflections.
