Question KEF R200c as Front L/R/C
Discussion in 'What Speakers Should I Buy?' started by Ruesha81, May 25, 2016.
  1. Ruesha81
    Ruesha81
    May 25, 2016
    2
    UK
    I am currently running Kef 3001 Centers as L/R/C and I am looking to upgrade to x3 Kef R200c, or should I go with a pair R300's with a R200c Center
    Has anyone run this configuration.
    I am looking at the spec, and since they are all going to match, then it should be a great Front setup.
    I will be driving this from a Denon X6200W, also I will be adding a pair of Kef R50 atmos speakers to create a 6.1.2. Remaining setup is 3 Kef eggs for the surrounds along with a PSW2500 Sub
  2. PSM1
    PSM1
    Dec 20, 2008
    26,271
    +5,426
    Having exactly the same speaker across the front 3 is the ideal situation so there is no reason why 3 R200c would not work very well for you.
  3. gibbsy
    gibbsy
    May 17, 2007
    12,337
    3
    Cwm Cynon, De Cymru
    +6,676
    Why not if you have the space. I have a 200 as a centre and it really is a good speaker, but it is a fair old size. If I had had the room would I have gone down the route of three of them, for what, £1900? The answer has to be no, I prefer the look, and balance, of two 300s with a 600 centre for the same money.
  4. Ruesha81
    Ruesha81
    May 25, 2016
    2
    UK
    Just ordered x3 R200c, will let you know how the set sounds
