Your advice/opinions appreciated for the following;
Currently running Denon AVR3803 to 5.1 setup; KEF Q65SEs front, KEF Q9C centre, Mission 77DS rear, REL Q100e sub (speakers biwired where poss)
I would like to bring the rears into line with KEFs, and finally put a speaker on the end of the centre rear cable I installed about a year ago!
But...
I am in a 'less than ideal' room; there is no space to locate the rears behind me so I must have them fire sideways (Wallmounting is not an option so it's Atacama SE10s). I like dipoles but spoke to KEF who said Q2DSs must be wall mounted. Period.
Therefore is my only option Q1s?
My mythical centre rear (single, room not big enough for a pair) will be immediately behind me, but with no wall
, so will have to be stand mounted as well (SE10) - should I go for another Q1 or would the Q6C be more suitable? I am assuming that the Q9C is overkill for a centre rear. (Will I be OK to put a larger mounting plate on the stand with bluetack, and sit the Q6C on top of that?)
Any comments folks? As ever, this forum is a superb resource, and has helped me avoid expensive mistakes in the past!
BTW I had intended to swap the Q65SEs for Q7s but I gather from several other threads here that this is not really worth it
