kef Q's or B&W 600 S3's
R
ramiro
I need to buy a sorround speaker package:
For now my short is:
- B&W S3: 603 + LCR60 + 600
- KEF Q: Q5 + Q9c + Q8s
wich one should i choose?
are these right combos within each series ?
thx.
ramiro.
mutley
If possible try to demo both and choose for yourself! some people prefer KEF other B&W. that's personal taste and isn't the same for everyone. they're both great speakers, i prefer B&W for movies, KEF with music. What will be their main use?
R
ricdiggle
I have Q3s, Q9c and 3 Eggs for the rears.
I had a look at the Q8s but thought they looked liked really big computer speakers. If I had it all to do again, I'd buy Q1s for the rears. My plan now is to move the Q3s to the back and put some Q7 up front.
I tried both setups, Kef and B&W and for me there was no contest with music. The Kefs revealed a lot more detail. With a movie sound track it was very close.
IMHO the Kefs look far better too.
Hope that's of some use.
Richard.
Miniholic
Ramiro
I listened to both set ups, and went for the B&Ws. I've got 602.5's and an LCR600 up front with 601's for surrounds, would probably buy 600's now, but they weren't out when I got mine last september (may get a pair of 600's to use for surround back in the next few months when i uprage to 7.1).
There were two reasons I went for the B&W set up. I thought that they were more involving to listen to, and seemed to give a fuller soundstage. And at the time, you could only buy the eggs as a package and not singularly, so i wouldn't be able to upgrade to 7.1 as easily.
You might find the 603's a little overpowering with the LCR60, my dealer even suggested getting the LCR600 to partner my speakers, which are much smaller than the 603, and have fewer drivers.
I had originally considered getting the 603's myself, but the dealer talked me out of it, and saved me money, as he said the extra low-end range would be wasted when I got a sub anyway (not got one yet as i decided to wait as little while so i could afford a better amp).
Which amp are you using, i'm running mine with a denon 3802, and from other posts on here, it seems a few people are using this amp with the Kef eggs with good results.
Speaker choice is really a matter of personal preference, so the best thing to do is arrange a back to back test if you can, but you can't really go far wrong with either of these choices.
Hope this helps,
R
rob_w
I think Antonios got a point there...
I use the 602's /cc6 at front, with 601's at rear and reckon 5 601's + sub would beat it (at movies anyway....) - I prefer the bass to go as low as possible in stereo for music.....
Matching all 5 speakers could sound great.
Rob
🎬 The Top 20 Most Anticipated Movies of 2024
Back
