kef Q9c
P
philthyanimal
Just got a pair of Q1's and a Q9c to replace my front and centre eggs, so i have a couple of questions.
On the bottom of the Q9c there are 2 rubber spikes, should there be one of these at the back?
Also how do i set the cross over and speaker sizes now on my kef sub and AX3 amp.
P
philthyanimal
would that be a long black screw with a small rubber stopper on it, not a rubber spike like the front two legs.:blush:
I nearly threw this out. If it is i'll fit it tonight. Thanks for the help :thumbsup:
Mose
The screw allows you to angle the centre channel the way you need it. I set up a laser level on mine to get it just right.
