Kef Q6c, Good match for Q1?
Discussion in 'Home Cinema Speakers' started by jagr, Apr 27, 2005.
  1. jagr
    jagr
    Apr 6, 2003
    1,402
    Cheshire
    +115
    Hi All,
    Is a Q6c a worth while centre speaker for the Q1's? Or am I better off waiting for a good priced Q9c?
  2. deanym
    deanym
    May 29, 2004
    1,833
    +143
    depends on room size and position, a smallroom, q6, big room, q9.
  3. Helicon
    Helicon
    Apr 4, 2005
    5,018
    +261
    The Q9c is the closest voice match to the Q1 - apart from another Q1 of course......
  4. Tejstar
    Tejstar
    Dec 4, 2002
    22,822
    London
    +1,091
    I agree with what has been said above. I run Q4's with a Q6c, however I'm now upgrading to a Q9c as the Q6c is too weak for me room. I did not consider this before I bought it.
  5. jagr
    jagr
    Apr 6, 2003
    1,402
    Cheshire
    +115
    Thanks for responses.
    My room is 4m long and 3m wide.
    I have just come back from superfi with a maple Q6c.
    The first reason was, they only had the Q9c in dark apple and the second reason was they did it for me for only £100.
    Will set it up and see how it sounds.
