KEF Q-Series or Monitor Audio Silver?
Discussion in 'Home Cinema Speakers' started by TimDeLAY, Dec 10, 2004.
  1. TimDeLAY
    TimDeLAY
    Hello,
    I am about to bye a home theater setup... up to now I had decided for the Monitor Audio Silver series (S10, centre & silver bipoles). A friend though told me to also check the KEF Q series (Q7, Q9c, Q2ds - he can find a good deal for me). I want them for 70% for home cinema use and 30% for music. Let me also note that I like loads of bass! I should also add that for sub I'm planning to use the Velodyne CHT-15R (when released). Which ones do you think I should go for? The problem is that I can't audition them side by side (I only find them in different stores) so I can't really tell which I like more. I think the MAs have more bass though (which I like a lot!). Ok, given that I'll be using a good sub it is not an issue for movies; for music however, where no sub will be playing, the speakers bass does make a difference. So, any opinions?
    Thank you very much in advance!
