Kef Psw4000
Discussion in 'Subwoofers' started by lowrider, Jun 15, 2004.
  1. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    My brother bought KEF Ref 4 x 201 + 202C + PSW4000 subwoofer...
    The speakers sound very good, but the sub, set at almost minimum, 1 on the visor sounds boomy, doesnt integrate at all, is it this bad, or will it improve with run-in... :confused:
    As it sounds now I would prefer a Quake... :eek:
  2. KEF Ben
    KEF Ben
    Dec 11, 2002
    10
    3
    KEF
    Have you tried the slope switch?
    The PSW4000 is a pretty darn good subwoofer when set up with care.
    Also try Music mode, Cinema does get a bit lively!
    A good workout with some DVD's or dance music should help run it in.
  3. quadophile
    quadophile
    Sep 6, 2003
    78
    11
    +4
    You are a REL user so doubt anything esle will give you what REL can!
  4. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Actually, the bass sounds much better with the speakers in large, without subwoofer... :rolleyes:
    I have lived with two Strata III a few years, I guess I know how to calibrate a sub, of course I use music mode, the speakers are all set to small with xover at 60hz and bass to sub via LFE, without using the sub´s xover, so I guess the slope shouldn´t matter, although I do hear a difference, slightly better with 24db slope... :zonked:
