Kef psw2000 and denon dht-fs5
Discussion in 'Subwoofers' started by johnmerrick, Feb 7, 2009.
  1. johnmerrick
    johnmerrick
    Jan 31, 2005
    741
    Poole
    +15
    i have just been given the above sub to go with my recently purchased denon soundbar. the latter has a subwoofer pre out terminal but the sub has 4 sockets line in left and right and another two which i cant quite remember what they are!. any ideas how i could connect these two together? i'm a bit unsure. i have also been given a coax cable by the hifi shop ( i asked for a subwoofer cable).
    i am a bit lost here because i have never used a sub before.
    thanks in advance.
    hope someone can help!
    edit: i basically have one ouptut from the soundbar(amp) and two on the sub. do i just use a set of phono plugs?
  2. Richy8558
    Richy8558
    Aug 18, 2008
    40
    Maidstone
    +8
    You can plug the cable in to either the line in left or the line in right inputs. It does not matter which one as the .1 signal to the subwoofer is only a mono signal. :)
