@Spick72 Hi can i ask if youve got these setup as yet.
Afew pics would be good and how are they doing as im trying to decide on ls50 or r3 at pressent.
I like the idea of having a speaker on its side as the centre channel.
Did you have any issues ordering an odd number of the speakers?
Looks great, can I ask what receiver you are using with the KEF's and do you feel like there's enough power in it?
Nice set up
Even though I don’t have the LS50 Meta, I have been using the old Kef LS50 as front and center in my 5.2.4 all Kef system, the other speaker are the Kef e305 eggs.
I was initially worried about using the LS50 as a center, as it is normally recommended to use a larger speaker for center duties but I have not found a single weak point as yet with the LS50. I watch Blu-rays, Sky,Apple Tv, Disney+ and Netflix and it has been superb. I don’t know if the AV receiver makes a difference but in combination with the Marantz SR 7013 it has been very impressive. I bought the 7013 and LS50 on sale as newer versions were released. Maybe the LS50 Meta is better but for the price the LS50 is hard to beat. I paid 999 euros total for all 3. Truly a great speaker.
Wayden
Hi Brownvim,I have the Kef E305 home system connected to a Denon 2500x AVR.
What are the LS50s like in comparison to the front eggs?
You planning on using a separate amp for the fronts or an all in one AVR to drive all speakers? Also do you watch just movies or will you be using it for music a lot?Interesting- can someone recommend a good AV amp for a 5.1.2 surround with the meta s please?
Thanks - My plan was to use this for movies primarily ... What do you suggest please.
Thanks but can you please outline how you use a separate power amp for the metas etc? Are the metas still hooked up to the 3700?
