KEF launches new custom install speaker
Discussion in 'News' started by John Archer, Jul 21, 2005.
  1. John Archer
    John Archer
    KEF has just announced the launch of an upgraded version of its acclaimed Ci130 custom install speaker.
    Designed to be as unobtrusive as possible, the Ci Series Ci130.2QS and Ci130.2QR are high-fidelity flush-mount loudspeakers utilising KEF’s Uni-Q® driver array technology. This is claimed to give the round and square bezel speakers inherently smooth dispersion characteristics that should fill any normal room with an expansive and rich sound stage.
    The driver array is mounted into a moulded ABS baffle and can be easily and quickly installed with the moisture-resistant bracket and fixings apparently allowing placement in the harshest environments, such as bathrooms or even outside (under eaves).
    Features
    The Ci130.2QS and Ci130.2QR combine 50W power handling and 86dB sensitivity. A 130mm (51.4”) bass/mid driver promises good bass extension along with a 19mm (3.4”) aluminium dome tweeter to provide enhanced power handling and smooth response.
    The bezel and grille can be painted or covered by fabric to match the interior décor.
    Suggested Retail Prices (including VAT): From around £100 each.
