Kef Kube 200?
Discussion in 'AV Receivers & Amplifiers' started by matblack, Apr 24, 2005.
  1. matblack
    matblack
    Jul 30, 2003
    404
    +10
    Anyone know if it is possible to integrate the Kef Kube 200 with an AV amp?
    From this pic here
    [​IMG]
    It seems it takes phono cables, the only way I can see of making it work would be by using a power amp and put the Kube inbetween. I'm confused :)
    Any ideas :confused:
    MB
  2. wookie
    wookie
    Yeah, you would need to connect it between a pre and power, or be using an amp with "pre out" & "main in" sockets for the front.
    NAD, PIONEER, MARANTZ have these.
  3. matblack
    matblack
    Jul 30, 2003
    404
    +10
    Oooo might be able to do it then as I have a Marantz SR5400 :)
    So you know if the difference is a particularly noticeable improvement?
    thanks
    MB
  4. wookie
    wookie
    I would use it only with music (between CD player or dvd player and analogue inputs).
    Any bass boosting eq can be bad with movies.
    Do you have a sub?
    I would run the Ref's as small for movies and use the KUBE for music without the sub.
    If no sub, run the fronts as Large without KUBE.
  5. matblack
    matblack
    Jul 30, 2003
    404
    +10
    I've tried the Kef Refs as both large and small and they add a new dimension as large. However, the Marantz amp has two different settings when speakers are set as large, a 'mix' setting which diverts the signal to the sub at a specific frequency and a 'both' setting which lets both fronts and sub have the signal. I'm using the both one which means the fronts reinforce the sub and they do go pretty low :)
    I'll play around a bit later, I'm with you on the idea of adding the Kube between the CD player and the amp, I can understand the issues with adding bass to a movie soundtrack which isn't designed to be there.
    Thanks for the advice, the Kube is on an auction site so I'll make a decision when I have an idea of the final cost :)
    MB
