I can't help specifically with the Kube, but I have the 3005SE speaker package, and hope the following might help:
- Does this happen with all your sources?
- Does this happen with true 5.1 signals or with processed signals?
- Does it happen at all volume levels?
I notice that if I'm listening to regular tv through a stereo signal (i.e. not receiving a discreet .1 channel), and I'm listening at moderate volumes, my Sub will regularly turn itself off (light goes red instead of blue). However when watching Blueray/DVD/Xbox360 etc with a 5.1 signal, it remains on all the time.
I suspect it goes into power saving after a period of not receiving anything to do (which makes sense), and on low volumes, my amp just isn't sending anything to the Sub.
If its doing it in other situations of course, then its a different story.
My sub quickly turns back on when the volume is increased, or there is some base to handle.
Not sure that helps, but good luck !!
