KEF KHT3000 stands - alternates
whooshavf
Can anyone tell me if the 3000 surround apeakers will fit on any other KEF stands, or will they only fit the 3000 stands.
Will they fit on any other brand of stand?
tommy060289
From what i can tell they are the only ones specifically made to fit them. You could always put them on top of universal bookshelf speaker stands but id expect the results to be ugly and even more expensive!
ijg0
The KEF KHT3000 eggs come with small brackets which can be seen here. The small bracket can be wall mounted, placed on a flat surface or detached and the KEFT floor stands used instead.
You could place the bracket on top of another brand stand but it would look a bit odd.
The KEF stands do look the part and I think cost me around £125 a pair new.
Podcast: Trinnov Room Optimiser: A full explanation of Trinnov and its room optimiser technology
