Kef KHT2005.2 setup questions
Discussion in 'Home Cinema Speakers' started by igstephenson, Nov 5, 2003.
  1. igstephenson
    igstephenson
    I've just got a set of the new Kef KHT2005.2 and was wondering how to best set it up.
    I am using a Pionner VSXC501 receiver and QED cables. With regards to the crossover frequency, do I just set this to maximum as the receiver will handle the crossover frequency itself? Or do I need to adjust it manually to get the best integration?
    Also, what does the slope switch do - the manual only says it is "used to adjust transition between speakers and subwoofer" - what should this be set to as default (12 or 24db?) and what is recommended for a small room setup?
    Many thanks,
    Ian
    Loewe Mimo 32
    Pioneer 565a
    Pioneer VSX-C501S
    Kef KHT2005.2
  2. mooky
    mooky
    Ian,
    I asked the same questions when I first got my 2005.2's. In the end I experimented as well as looked on the KEF home page and supplied little booklet. My crossover is set at 12 O'clock on the sub, which I believe is 80hz. Most people on here told me to set the crossover to maximum but I didn't like the sound when I did this and the KEF booklet seemed to suggest that this was correct. My amp has the crossover for LFE fixed at 90hz, but if your amp has a selection try to use the one nearest 80hz.
    The same goes for phase. I tried phase at 0, but after experimentation ended up around the 12 O'clock mark. The volumne you'll also need to tune for your room either by ear, or better by SPL.
    I Left the slope button as it came. I think it effects the roll off of the crossover to be sharper or smoother, depending on your main speakers.
    Mark.
  3. igstephenson
    igstephenson
    Mark,
    Thanks for the response, I shall have a tweak of the settings and see how it goes. BTW, is the slop switch set to 12 or 24db as default? I've fiddled that much I can't remember what its default is?
    Ian
  4. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Remember to set the amp to small for all speakers, this is a must for the eggs. There are several threads on egg set up from the past. Try a search for more info
    Croc
  5. rscott4563
    rscott4563
    Jan 21, 2003
    1,051
    38
    Cumbria
    If your running the sub from the LFE amp output then it doesnt matter where you set the crossover on the sub (as long as its past 80hz) because its controlled by the amp, thats why people will have told you to set it at maximum, to ensure you dont have it set too low and missout on anything between the setting you have on the sub and the amp setting. For example if you had the sub crossover set to 60hz and the amp was set to 90hz as you say its fixed, then you would be losing everything between 60 and 90hz....
