Kef KHT2005.2 Center Channel Upgrade
Discussion in 'Home Cinema Speakers' started by iclarke, Jan 1, 2007.
  1. iclarke
    iclarke
    Aug 28, 2003
    16
    3
    Guys,
    Any recommendations for the above as I'm sure I'm not the first person to do this :)
    Have been pretty happy with the standard setup (jncluding 6th Egg for the center rear channel) but always felt the front center channel was lacking much impact especially in movies or when watching TV. I'm about to relocate the center speaker from the top of the TV to the top shelf of the AV rack (LCD TV coming soon hopefully!) and I think this is going make it sound even weaker.
    I may also want to consider replacing the two front effect speakers with 'proper' floorstanding speakers at some point in the future so any advice on this would also be handy.
    Thanks in advance
    Ian.
  2. mistrip
    mistrip
    Aug 16, 2002
    319
    UK
    +12
    I think this has been asked a few times. But the general opinion seems to be another speaker from the kef range like the IQ? (something, can't remember the number?) or the centre from the 3005's or the 5000s.
    Also try changing the crossover to about 110Hz and upping the centre channel volume a few dB.
  3. huntere
    huntere
    Dec 30, 2004
    1,584
    63
    Perth, Australia
    +237
    Yep
    Lots of posts on this.
    I talked to KEF direct about it a year or two back. They recommended best tonal match was to use something from KHT range.
    Some have sucessfully used iQ6C ad 9C but very different beasts to KHT range.
  4. gasman1
    gasman1
    Oct 27, 2005
    707
    28
    Elstree, Herts
    +48
    If you're going to get floorstanders anyway, go iQ2c or iQ6c, then then the iQ5's or iQ7's for your floorstanders. Hope you've got plenty of cash, it seems upgraditis cause wallet haemorrhage.
