KEF KHT1005 wall brackets - and how do they work ?
Discussion in 'Home Cinema Speakers' started by Just_Dabbling, Jul 19, 2005.
  1. Just_Dabbling
    Just_Dabbling
    Does anybody have any experience of using the KHT1005 set with wall brackets ?
    I need to be able to mount them on side walls and get a bit of an angle on them, but as far as I can see, the brackets don't look like the will allow that angle ?
    Anybody with any real life experience, please !
    Dabbling
  2. Steve237
    Steve237
    Nov 15, 2004
    417
    +7
    I need some wall brackets that can be adjusted to direct the speakers in various directions also.....
  3. Just_Dabbling
    Just_Dabbling
    Andybody ?
