Kef KHT Sub-Woofer
Discussion in 'Subwoofers' started by Droogie 2001, Mar 2, 2002.
  1. Droogie 2001
    Droogie 2001
    Aug 19, 2001
    1,479
    Surrey
    +108
    I know there have been alot of posts regarding the setup of the Kef KHT sub woofer mainly because the manual is poor.
    I have read through lots of different posts and have tried all of the different setup's people suggest.
    Can I clarify this setup once and for all?!
    I have a Denon 3802 with the Kef Eggs.
    1) The Cross- over on the actual sub should be turned all of the way up or should it be all of the way down? (some posts contradict each other)
    2) The setup on the AMP's menus should be set to all 'small' speakers and the frequency set to 80hz or 120hz?
    3) Lastly the input volume on the sub obviously has alot to do with the depth of the bass (not to mention personal taste)
    but what kind of level would people recommend?
    As I say it obvously comes down to personal taste and I am not a bass freak but like a subtle powerful sound which does not intefere with the dialogue.
    Please can anyone help and set the record straight!
  2. JoeJoe
    JoeJoe
    I have mine set all the way to the right, cross over at 120 and all satellites set to small.
  3. Droogie 2001
    Droogie 2001
    Aug 19, 2001
    1,479
    Surrey
    +108
    Thanks for the reply.
    Its probably the longest response ever. I posted this in March 2002!
    :D :D :D
  4. JoeJoe
    JoeJoe
    LOL
    Kef now how recommended settings on their website.
    Unlike the manual!!
