KEF KHT 1005 wall brackets
Discussion in 'Home Cinema Speakers' started by Abbeygoo, Nov 4, 2005.
  1. Abbeygoo
    Abbeygoo
    Oct 19, 2005
    25,193
    Manchester
    +10,341
    Quick one - I have seen the KEF KHT 1005 wall brackets in brochures etc - does anyone know if you can angle the speakers once they are on the brackets? If so, by how much? cheers for your help.....
  2. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,421
    Manchester
    +6,168
    I've had a quick browse and can't find whether the brackets swivel(!) or not. I'd suggest sending an email to KEF or to Creative Audios - I'm sure they'll provide an answer.
  3. vcuares
    vcuares
    Bump. I'm also interested. Can the brackets be angled?
  4. Trancerii
    Trancerii
    Jan 10, 2004
    360
    28
    +47
    I have am using the wall brackets for the rear speakers for the KEF 1005, and you can angle them left and right. You cannot angle them by much though. As an example, the pic below shows them angled as far as they will go towards the camera:
    [​IMG]
  5. vcuares
    vcuares
    Thanks! the pic really helped. Could you confirm if it does at least goes up or down?
  6. Trancerii
    Trancerii
    Jan 10, 2004
    360
    28
    +47
    No, You cannot point them up or down, just left and right.
