KEF KFT 2005 mk1 or Mordaunt Short Premiere plus
Discussion in 'Home Cinema Speakers' started by Gatekeeper, Jun 8, 2004.
  1. Gatekeeper
    Gatekeeper
    hi i have at last moved house. :clap: so i am in the market for some new speakers, to go with my denon 3801 amp. i like the look of the eggs ( mk1 not mk2 due to price ) but the Mordaunt Short Premiere plus has good reviews and are cheaper. so would you recommend premiere plus system or pay the extra £100 and get the mk1 eggs
    many thanks :)
  2. Fat Tony
    Fat Tony
    May 1, 2004
    644
    +20
    If this helps put the newer eggs into your budget, the .2's are going for £599 at Krish AV (and perhaps play.com, if I remember a recent post correctly).
    Edited to add: the sub on the .2's is 10" (vs 8") and much improved, going by all the reviews.
