Kef IQ10 wall bracket
Discussion in 'Home Cinema Speakers' started by marcus2704, Jan 29, 2009.
  1. marcus2704
    marcus2704
    Jul 10, 2003
    269
    Hemel Hempstead
    +9
    I bought these, perhaps without reading the description closely enough, as I only realised when they arrived that Im meant to screw the bracket into my lovely spanking new Kefs -
    KEF iQ10 SPEAKER BRACKETS (PAIR) - available from Superfi UK Visit http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/product_id/4529 for details
    Is this my only opton for wall mounting these, if so Ill have to go ahead, but Id prefer not to if a bracket exists thats suitable for the curved Kefs!
    Any advice (other than next time read the product info!) appreciated!
    cheers
  2. marcus2704
    marcus2704
    Jul 10, 2003
    269
    Hemel Hempstead
    +9
    hi does anyone have any alternate solutions for this, the retailer has advised this is the only bracket thats suitable for this speaker?
  3. paulr2006
    paulr2006
    Jun 30, 2007
    9,528
    Nottinghamshire
    +2,506
    I think your only answer would be a shelf if you don't use those brackets :)
  4. Formby
    Formby
    May 20, 2009
    NO! Wait! Don't screw into your lovely speakers! I hope you haven't yet, although it is likely that you have. What there is, is, a couple of pre-drilled wholes in the back of the iQ10s. Unfortunately, they appear to only be on certain model numbers.
    Look at page four of the manual that came with your speakers. Here's a link to the .pdf file: http://www2.kef.com/resources/Current Products/Loudspeakers/Q Series/_manuals/q_series_manual-en.pdf
    It also seems to be only the older model numbers that use the pre-drilled wholes! I would have thought that KEF would find pre-drilled wholes to be a much better design. Or perhaps it would cost them more to manufacture! lol. Take care, and great choice in speakers!
    Formby.
    P.S. This is like the only place that gives this information on google! So I hope it helps lots of people. Thanks to some guy at AVSForums who found this for me!
