KEF Foam Inserts
Discussion in 'Home Cinema Speakers' started by NPM108, Dec 14, 2004.
  1. NPM108
    NPM108
    Nov 6, 2004
    109
    16
    Hi All,
    I was wondering exactly what the Foam Inserts supplied with my Q7s are meant for. Are they used to control the bass from the speakers or to help with the running in?
    Any advice would be appreciated.
    Setup:
    Q7s, Q9c, REL Q150E, Yam 630RDS, Q2ds and currently Mission! rear centre
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    The foam has nothing to do with running your speakers in, it's more for bass management.
  3. NPM108
    NPM108
    Nov 6, 2004
    109
    16
    Ah okay thanks, so its for controlling/reducing the bass???
  4. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    Yep, that's right. Try comparing it yourself by putting them in and out with the same music. You should hear a difference :)
