kef eggs
Discussion in 'AV Receivers & Amplifiers' started by neilos70, May 31, 2003.
  1. neilos70
    neilos70
    May 28, 2003
    233
    hertfordshire
    +4
    really thinking about getting a set to complement a new amp...which im demoing n/week.
    i want to keep my bw602`s as fnt l&r but need to upgrade the rest of my spkrs ie ctr, rear l&r and poss ctr rear etc
    so should i spend the dosh and get the eggs or are there any other alternatives?...is this the best way to do it? or are there cheaper spkr alternatives ie yammy, etc.
    compact spks are the best choice as not a lot of room for bulky spkrs.
    :confused:
  2. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    You should really think about keeping the centre to match your front left and right.
    Eggs, VM1 are about the same price, with Gallio balls coming in slightly higher priced. Other options for compact speakers might be somthing like Missions m7d or the m70 as they are both quite small and both (I think) will wall mount. Or stick with B&W for surronds and get a pair or 2 of DM600 which again wall mount.
    Vikki
  3. neilos70
    neilos70
    May 28, 2003
    233
    hertfordshire
    +4
    thought about sacking the 602`s for the complete vm1 package but i simply cant get shot of them.
    need to think about all of this, hard isnt it?:eek:
  4. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    Might be worth demoing how well the VM1 goes with the 602s ... 1 might work well as a centre but I'm not sure how closely matched they are in sound quality.
  5. neilos70
    neilos70
    May 28, 2003
    233
    hertfordshire
    +4
    good idea....ta very much
  6. Paul Reading
    Paul Reading
    Feb 2, 2003
    96
    Well I have listened to the Eggs and there is no subsitiute for larger speakers in my opinion.
    Having said that, like you I think that in some instances the small size is attractive, but I have got around the problem and would reccomend Artcoustic speakers, they are fantastic and really are attractive.
