kef eggs, any good for stereo?
Hi, looking to downsize my diamond 10.1 due to a house move. Wondering if the kef eggs would be any good running off an integrated amp, obviously with no sub as I'm guessing the eggs don't work like the bose acoustimass and are just a normal 5.1 setup?
Sent from my Desire HD using AVForums
sputs40
the kef eggs will not be very good just as a stereo pair you would need a sub your not going to get much bass from them
Thanks, I had a feeling that might be the case. Don't suppose you know of anything small that could do the job and at around 150
sputs40
not sure are you looking for something smaller then 10.1s if your not going to have room for small speakers what about a good pair of headphones saying that the 10.1 dont take up a lot of room
Yeah, I was considering the bose acoustimass just because its small and pretty cheap used. I know they don't get the best reviews around here but I have some of their headphones and have to say I like them more than my grado sr60 ones.
sputs40
you could look for some cheap kef eggs and a sub they would be better then bose . i have 3 kef eggs and a kef sub i was thinking about selling soon
a8ch
Imo you need to stick to a two way system, with a 100mm bass/mid a minimum. With similar needs I eventually compromised with the JBL Control 1's. You also have the QA1010 which is a similar size. Although the 1010 was the better build/looking the C1's sounded better for me, so do listen. Also remember the better the amp the better they will shine. You may find some Lektor ones at that price but I suspect they will be the same size as your 'dales.
Thanks I'll see if I can get a listen to some jbl speakers. Don't know why but something about the qa bothers me, im yet to hear them but I just don't warm to them. Silly really. The amp I have now is a Cambridge audio a5. Nothing too ground breaking but I enjoy it.
KUBBY
If you like Wharfedale,would the 10.0 be worth looking at? They will do better than the Eggs.
K.
Sent from my 6 year old Toshiba satellite Pro using Chrome.
moss
Jbl control 1 pro (135mm speaker) sound brilliant - give these a go. I think they are around £120 a pair.
Cheers mark.
PSM1 said:
A lot of subs have high level inputs so you could use a sub with your stereo amp without an issue.
Ah that I didn't know. Could you explain it a bit for me? Sorry I'm on my mobile and Google searching is too painful
Cheers mark.
Are the control one the same as the control one pro?
PSM1
Basically they use the speaker level connections. Some will have the speaker cables going into the sub and then from the sub to the speakers while others will have the sub wired in parallel with the speakers (so the sub and the speakers connect to the same speaker outputs on the amp).
Ok I'm with you. Thanks for that, didn't think that was possible. Could you recommend any subs or brands to look at? Cheers.
PSM1
BK Electronics do a good range of subs at great prices. If these are a little expensive then the Wharfedale SW150 is worth a look as well.
a8ch
The main differences, the pro are 4 ohm and has a polycarbonate dome tweeter, the standard one is 8 ohm and has a titanium dome tweeter. Interestingly the pro touts a 135mm driver yet the cabinet dimensions of both are identical in the specs?
