KEF Eggs advice
Discussion in 'Home Cinema Speakers' started by wilders, Sep 25, 2003.
  1. wilders
    wilders
    Sep 16, 2002
    315
    Portsmouth
    +5
    Hello,
    I have a reasonable amp and am looking to get the right speakers.
    My room is 23' x 14', and was wondering if the Kef eggs will be enough to fill the room, or should i really look for decent floorstanders and rears?
    This will be a 50/50 split movies and music.
    Cheers for any advice
    Wil.
  2. nathan_silly
    nathan_silly
    For that sized room (and especially since you're interested in music system) I would go for standmounts, say same sized speakers as Kef Q1's. Although I'm not recommending Kef Q1's- just as example.
  3. lmccauley
    lmccauley
    Oct 24, 2000
    3,436
    Newcastle
    +272
    I wasn't impressed with the kef eggs when I heard them demo-ed. Do you have a particular budget or other constraints?
    Cheers,
    Liam
  4. wilders
    wilders
    Sep 16, 2002
    315
    Portsmouth
    +5
    I was dubious that speaker so small could fill my room, which is fairly large.
    Can anyone recommend some floorstanders/rears/centre
    My budget would be around £600 but can move up should the right gear be close to that.
    If there are some stunners for £800 I'd go for it...
    Wil
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    There is an interesting Monitor Audio system that hifibitz are selling for £750 against a normal retail price of £980. This comprises a pair of B4 floorstanders for the front, BFX speakers for the rears plus a matching centre and a subwoofer.
    Details on their website here
  6. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    The eggs are fine unless you are deaf for the money.
    Just try a larger sub or dual 2010's if not enough.
    Trust me i've just let go of ref 3.2's and hgs-18 for a kht2005.2.
    Granted not as good,but not that much in it really considering the price difference
