kef cresta 1 opinions?
Discussion in 'Home Cinema Speakers' started by spark, Jun 26, 2002.
  1. spark
    spark
    Considering a pair of KEF Cresta 1's as rears.
    Kenwood 5050 amp.
    Mordaunt short front and centre.
    Are they any good?
    If so, what's the best way to mount them?
    Cheers.
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    The Kef´s are great speakers for the money, but ideally you would have speakers from the same manufacturer for both fronts and rears.
    You can standmount the speakers or wallmount with a bracket.
  3. Torque
    Torque
    What's the feeling on using the Cresta centre in a Cresta1 5.1 setup?
    5x Cresta1:
    pro - all the same
    con - positioning the Cresta1 as centre above/below TV. Awkward geometry, and BTW are they magnetically shielded? (the Kef website doesn't say). Another con, you buy them in pairs so end up with an extra one to tempt you into buying a more expensive 6.1 amp ;)
    4xCresta1 + CrestaC:
    pro - centre horizontal, fit more easily above TV, slightly higher power for speech
    con - any matching issues?
    What do you think?
  4. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Going on a previous thread about monitor damage, Id say they're not magnetically shielded!!
    Dave
  5. colinloves
    colinloves
    No shielding on the Cresta 1's. Of course there is shielding on the Cresta centre (but I guess that goes without saying)
    --(still looking into seeing of Kef do a shielding device for their speakers)--
  6. Torque
    Torque
    If you could get a shielding device, would you rather use that than use the shielded centre? Is a dedicated centre so much to be avoided that it's worth the hassle? Could anyone with a Cresta centre comment on how well it matches the others?
  7. Ron Locke
    Ron Locke
    We do not offer a shielding kit for the Cresta range, if you want to use the Cresta 1,2 or 3 (not shielded) as front L/R channels, then I suggest a safe distance of at least 18" from the TV/Monitor.
    Of course using the Cresta 1 as rears is no problem at all, and for the price, you will get a lot of performance.
    Best Regards
  8. colinloves
    colinloves
    Hi Ron and thanks for clearing that up for me.
    I have a very small room and have to place my front right Cresta 1 next to my PC monitor (about 2 inchs away). So I really really need some kind of shielding device for it.
    Could you tell me what is the magnet power in the cresta 1's and what size/power magnet I would need to counter the speaker magnet. Im sure with a bit of DIY I'll will get around my little problem. Hope you can help in this matter. as I really cant afford to get a whole new bunch of speakers just to solve me little problem.
