KEF 55.2 series vs Mission 78 series
Discussion in 'Home Cinema Speakers' started by titanax, Jan 29, 2002.
  1. titanax
    titanax
    I have heard of the KEFs 55.2 but I can't find them on the website; instead I get to see their Q series which only has the Q5. Is this the same model ? If it isn't then what is the model for the surround & center speakers that complement the Q55.2 , i.e same drivers.
    Are the Q55.2 in the same league as the Mission 78s?
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,492
    United Kingdom
    +2,029
    The Kef Q range has been updated now to the ones on their website.
    The old range Q55, 35,15 etc etc is being discounted at lots of places.
    The centre that complements the Q55 is the Q95 and for surrounds either the Q15 or Q85.
    I prefer the Kefs to the Mission´s but thats my personal opinion.
    If your looking at the Kef´s then you´d be better off getting the Model 100 centre as this is much better than the Q95 centre. It will still match quite well with the other Kefs.
  3. titanax
    titanax
    jase wat sub would you recommend for either models ?
