KEF 5.1 to 7.1 setup - additional speakers recommended?
Discussion in 'Home Cinema Speakers' started by gbdavisd, Sep 20, 2005.
  1. gbdavisd
    gbdavisd
    Mar 29, 2004
    350
    Dorset
    +7
    Hi all.
    I have the following 5 speaker configuration
    Kef Reference 2.2 fronts
    Kef 200c Centre
    Kef 65ds rears
    These are running off a Yamaha DSP-A1 at present.
    I'm thinking about an AMP upgrade (another thread to be raised shortly!) but wondered if anyone could recommend suitable (available) speakers to fit in with the above setup.
    I have a Kef 100c Centre as well, which is spare at the mo. Don't suppose this could be re-used ?
    Damian :)
  2. Steve N
    Steve N
    Feb 3, 2005
    10,802
    Peterborough
    +2,217
    This would serve reasonably well as a surround effects speaker (6.1)
    The only problem would be the asthetics or its placing - a small shelf would suffice. Ideally though, I think dipoles are best in this position.
    I have the same fronts and centre as you but use Q2DS as rears.
    I prefer these to the 65ds but for matching purposes the ideal rears for the front three would be the old 34DS (I'm currently looking for some)
  3. gbdavisd
    gbdavisd
    Mar 29, 2004
    350
    Dorset
    +7
    Cheers,
    Yes, I think if i could get a pair of 35DS' then i'd use them with the 65DS's as the surround group. Problem is getting hold of some :(
    Might have to speak to Kef directly and see if they can offer some tonally accurate compromise speakers from the current range :D
    I'll post if i get anywhere with this.
    Now if i could just make my mind up on a replacement for my Panny Gen 6 SD panel...
  4. Steve N
    Steve N
    Feb 3, 2005
    10,802
    Peterborough
    +2,217
    Already done this :) It was kef who told me what I passed on to you. That was about a year ago so things may have changed.
    Let me know if you get any other info or recommendations.
  5. gbdavisd
    gbdavisd
    Mar 29, 2004
    350
    Dorset
    +7
    Will do.
    Damian :smashin:
