KEF 5.1 Setup, best layout
Discussion in 'Home Cinema Speakers' started by RainbowShooter, Feb 26, 2014.
  1. RainbowShooter
    RainbowShooter
    Feb 26, 2014
    41
    11
    St Albans, Hertfordshire
    +6
    I've been given a secondhand 5.1 setup of KEF speakers and looking for a bit of advice on layout etc.
    The speakers are:
    2 x T101 (Only have the wall brackets)
    2 X HTS/HTC 2001.3
    1 X T301C (Seems to only have table top mount)
    1 x KEF Kube-2
    Any suggestions on placement of the Front/Rears? Should I use the 2001.3 as fronts or the T101s? Where would be the best place to look for a T301C wall mount bracket? I've had a quick look online but can't find anything!
    Many thanks for any help!
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    Considering you have the T centre I would use the T101 as fronts since you want the front 3 to be the same make and model to give the best overall soundstage. Then use the 2001 as rears.
  3. RainbowShooter
    RainbowShooter
    Feb 26, 2014
    41
    11
    +6
    Great, thank you. Just seen that they make a T301 pair!
