Kef 3005HD2 - any information??
Discussion in 'Home Cinema Speakers' started by lunch_box, Jan 5, 2012.
  1. lunch_box
    lunch_box
    Dec 4, 2006
    3,094
    Parts Unknown
    +136
    Anyone know anything about the Kef 3005HD2 package that Richer Sounds are selling??
    It seems massively cheaper than the 3005 se range and the only differences I can see from the pics are different centre and sub.
    Is this the case or are the 4 sattelites different as well??
    any advice would be top banana :D
  2. hifix
    hifix
    Mar 7, 2006
    12,279
    2
    Coventry, West Midlands
    +2,419
    It comes with the KEF T2 subwoofer that usually partners the T series rather than the more capable HTB2se sub that comes with the usual KHT3005se package. It's worth a little extra for the SE package, which retails for £500 on its own, using dual bass drivers (one ABR) compared to the T2's single driver.
    Here's KEF's page for the KHT3005 package and it's options.
  3. lunch_box
    lunch_box
    Dec 4, 2006
    3,094
    Parts Unknown
    +136
    Thanks David.
    So is the centre speaker also different from the se series?? I am weighing up if the se series is worth approx 350 more than the 3005hd2.
  4. hifix
    hifix
    Mar 7, 2006
    12,279
    2
    +2,419
    Judging by their pic, it does look like a standard satellite, not the normal centre that comes with the 3005se package.
