New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
hi,
Just setting up these speakers, and above where the cables go in there is a piece of sponge in a hole , should this stay in or come out...
Daft question I know, but not sure..
Many thanks
Max
I wondered the same when I got my 3005SE. A bit of research told me that the sponge is a port bung. I believe it's used to influence the bass levels i.e. you can take it out if you wish. For my setup I left this in but you can experiment if you wish. For more info search for 'port bung'.
The port is used to vent the air displaced as the speaker cone moves as it's driven. Port bungs are used to prevent the 'boom' associated with placing the (rear) port close to a wall.
Depends on what you prefer, sound-wise with regards to removal..
