Kef 201 as mains ?
Discussion in 'Home Cinema Speakers' started by skinnyfat, May 23, 2005.
  1. skinnyfat
    skinnyfat
    Hi there
    I am thinking of upgrading my Q7's and seeing as I cant get the Q11 in South Africa I was thinking of going for the Kef reference 201 as mains. Has anyone tried matching them with the Q1's and the Q2ds ? Ignore my receiver below, Yammy RXV 2500 on the way.
    Thanks for the advice in advance
    Skinny
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    THey shouod work quite well together as most of the Kef range of speakers a quite a close tonal match to each other. Just for your information also the Q11s are a US product only hence why they are not available in SA.
  3. skinnyfat
    skinnyfat
    One further question. I know the Kef ref series is quite power hungry, do you think the Yamaha 2500 will be sufficient or should I look at a good stereo amp to run the 201's off ?
    Skinny
