Kef 2005 set up & wiring
Discussion in 'Home Cinema Speakers' started by James Sharp, Oct 24, 2001.
  1. James Sharp
    James Sharp
    When I first bought the sub/sat set I bought the cheapest wires possible as I knew I was about to move to a different house with different dimensions.
    Now that I am in I really want to get the system humming. Anybody got any advice on what wiring to buy or other set up tips? I've got a Yamaha DSP A5 amp.
    James
  2. Dumfy
    Dumfy
    Sep 25, 2001
    146
    Cardiff, UK
    Hi James,
    I've just installed the KEFs myself and used QED Qudos. It's around £2.50 per metre and works a treat.
    Regards
