KEF 2005 - any difference in .5 eggs?
Discussion in 'Home Cinema Speakers' started by keyser, Oct 1, 2003.
  1. keyser
    keyser
    Jul 23, 2000
    902
    gardabaer, Iceland
    What´s the difference between the 2005 eggs and the 2005.2 eggs specswise? Is there an audible difference?
    I can only get the older versions here in Iceland, I was wondering if I should get them or wait for the newer ones(are they the same price).
    I can´t buy them in singles here, but the price of a pair(the older version) is 200 pounds.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I haven't heard either but reading the reviews in the Home Cinema mags it would seem that there is quite a big audible difference in the newer version of the Eggs
  3. keyser
    keyser
    Jul 23, 2000
    902
    gardabaer, Iceland
    How much does the pair cost in the UK?
    I´m thinking of gettig two as back surrounds... cheaper and easier to get than two more bipoar Definitive Tech´s(I have BP2X´s as side surrounds).
    Does everyone that has two back surrounds place them both side by side... is there no sense in putting on higher(maybe even the ceiling) than the other?
  4. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Keysey...
    The centre rear surrounds are supposed to be placed higher on your back wall than the height of your L/R surround speakers, and they're supposed to be closer together than your front L/R speakers.
    They're also supposed to be 'aiming' downwards slightly towards your listening position, the aim of which (I'm assuming) is to prevent bad reflections from the front of your listening room.
    I certainately wouldn't advise ceiling mounting them though :D
  5. Dominic
    Dominic
    Mar 2, 2001
    288
    Essex
    +6
    keyser
    you can get the eggs as singles for around 80-100 GBP, try the usual suspects
    creative audio, Discountelectrical etc etc, not sure you could drive in and pick em up though.
  6. keyser
    keyser
    Jul 23, 2000
    902
    gardabaer, Iceland
    Thanks.
    I sit very close to the backwall, so I would probably just angle the speakers differently.
    "try the usual suspects" I live in Iceland... do you have any websites.
  7. andymc
    andymc
    Sep 18, 2003
    261
    Bedford
    +15
    The .5 eggs have a new driver supposedly which improves the midrange/treble response of the eggs. They also have a new subwoofer in the package and its meant to be a huge improvement.
    What HiFi S & V have just given them the 2003 Award in their catagory.
    Personally I think full size sounds better.
    Andy C
  8. z5461313
    z5461313
    Sep 18, 2001
    1,480
    +183
    I had a home demo and for movies I thought they were ok but music playback I could not get them to sound well
