kef 100c
Discussion in 'Home Cinema Speakers' started by marcoeser, Apr 1, 2002.
  1. marcoeser
    marcoeser
    Jul 17, 2000
    341
    Hello,
    Is £327 a good price for the above?
    or should I wait for the new range of speakers from Kef?
    marc :)
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,295
    United Kingdom
    +1,572
    You should be able to get this speaker cheaper.
    Its worth shopping around. Superfi has them for 319 quid at the moment. I´m sure it was cheaper a while back (250??)
    Check out www.superfi.co.uk
    The new Reference range centre speakers start at 1000 quid so depends if you´re looking to spend a LOT more.
    cheers
  3. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,797
    41
    Kent
    +18
    Model 100 centres quite often turn up in ex-dem lists from hi-end stores. Usually around £200.
    I recently missed one from Radfords at £165! :(
    Better hope you get there before I do though! :)
    Mark.
  4. marcoeser
    marcoeser
    Jul 17, 2000
    341
    don't worry Mark we're not in competition.:blush: I live in Greece so you should be there before me:(
