KEF 1005 popping noise
Discussion in 'Home Cinema Speakers' started by Ian182, Jun 18, 2004.
  1. Ian182
    Ian182
    Oct 15, 2002
    906
    46
    Leeds, West Yorkshire.
    +99
    Just a quickie............every time I turn on my amp, and the speakers power on, I get a loud popping noise from the right surround speaker, but none of the others. The speaker works perfectly well though ! :confused:
    I seem to remember this happened for a while when I first bought the amp and speakers, and then stopped, but its now started again.
    Any ideas what might be causing it ?
    Ian.
  2. wookie
    wookie
    Speakers only "pop" if they are fed a "pop" signal (no not boyzone etc) :laugh:
    The fault must lie in your amplifer.
  3. Fat Tony
    Fat Tony
    May 1, 2004
    644
    +20
    Swap cables/speakers over (either at the speaker end or the amp end) & you'll see it's the amp or the speaker causing this.
  4. Ian182
    Ian182
    Oct 15, 2002
    906
    46
    +99
    Still get the popping noise :confused:
    Swapped my rear speakers over, and the problem still only occurs on the
    right rear.
    Its bizarre - when I turn the amp on from "cold" the right rear comes on with a loud pop; turn it off and back on again quite quickly and it comes on with the normal click !
    What else could it be ? Speaker wire maybe ? I've not tried changing that yet........
    Ian.
  5. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +882
    The 'pop' generally is caused by a small power surge when the amp is turned on. You used to always be advised to turn the volume down to 0 prior to turning amps on to prevent damage to the speakers or amplification circutry but now-a-days I believe there is built in circutry in the amps to protect against this.
    By the sounds of it your amps protection needs to 'warm up' a little on that channel before it works correctly.
