Keeping plasma upright
Discussion in 'Plasma TVs Forum' started by jreed110, Mar 27, 2006.
  1. jreed110
    jreed110
    Mar 26, 2006
    167
    +7
    I've done a quick search and can't really find out exactly what I'm after.
    What are the facts about keeping a plasma tv upright at all times?? Why is this so? And is it only for long stretches that it really matters?
    On the instructions of my plasma stand it instructed me to lay the tv flat while putting the stand on, which I did, but I was dubious about doing this. Can this do it damage?
  2. kbj242
    kbj242
    Sep 23, 2005
    526
    28
    +32
    Hi Mate - they must be kept upright during transportation due to the fact that bumps etc will cause the screen to flex, and thus increase the change of damage / cracks etc.
    Laying in down (gently) on a soft level surface (eg living room carpet) isn't likely to cause problems - however, upright is always the safest option to my mind.
  3. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    It is really meant for transporting them, otherwise, so long as you careful with regards scratching the screen, laying it flat is not a problem at all.
