Hello.
I've recently purchased a couple of Sonos Connect amps for some in ceiling speakers upstairs.
I'd also like to add a hive unit for the boiler and some Philips hue lights.
I've already got power and Ethernet in the loft so thinking of adding the Sonos Connects, a router, hive unit and Phillips controller in the loft so they're out the way.
The lofts fully boarded and water tight etc but I'm a little concerned about the temperatures in the loft for the kit.
I've never took readings but it gets pretty cold up there in the winter (not below freezing) and hot during the summer.
Is this likely to cause any issues with the above kit or put it at a high risk of failure. I don't think the connect amps run too hot and they'll be powering in ceiling speakers so won't get much use.
I can locate them in a bedroom if absolutely necessary but it'd be easier and neater to stick them in the loft if suitable.
