M
mardale
In the winter it was easy - I bought a 3kw oil filled radiator with a climate controlling remote control. Having the remote in the house kept the cinema (converted garage) at the same temperature without resorting to extending the central heating.
Now it's getting warmer outside I'm finding (particularly this warm weekend) that the room goes up to 28 degrees before we're even in it. Add the amp, HTPC, projector and two bodies to that and it goes up to an unbearable 32 degrees. Heaven knows what it will reach in the summer.
The question is, then, how does everyone else using a converted garage keep it cool?
The obvious solution is air conditioning, but the last thing you need in a cinema is a b****y great fan in the corner of the room and the neighbours complaining about the volume because I've had to drill a great hole out for the exhaust vent.
HELP!
Matthew
HELP!
Matthew
