Keene Syncblaster cables ??
Discussion in 'Projectors, Screens & Video Processors' started by cosmic023, Oct 9, 2003.
  1. cosmic023
    cosmic023
    Feb 15, 2003
    1,369
    48
    Somerset
    +87
    Hi All,
    After looking for a new 10m scart lead for my Seleco SVP350, i seen the Syncblaster range are they worth buying one to connect to my new projector ??
    It's just that i've seen the scart to x5 BNC's video grade cable in the Keene catalogue. I need a length of 10m so would it be better to get the syncblaster cable or just buy the normal cable without the Syncblaster conersion ??
    I would like the best quality connection to go from my dvd player (Scart - RGB) to the CRT projector............
    Anybody own a cable like this ?? What are your thoughts ??
    Cosmic023
  2. stratman
    stratman
    I've got one and it works very well. I needed one to strip out and boost the sync signal for my NEC PG9+.
    regards, Simon.
  3. cosmic023
    cosmic023
    Feb 15, 2003
    1,369
    48
    Somerset
    +87
    Hi Stratman,
    How did the picture quality vary from a standard lead to a syncblaster lead, was it worth the extra money ??
    It's just that i could buy a good quality 10m scart to x5 BNC's from Keene for £50 But after looking at problems with RGB over long distance, and devices being fussy about a standard video connection, i just thought is it worth the £30 ??
    Cosmic023
  4. stratman
    stratman
    I needed to get the syncblaster because the sync voltage produced by the scart output of my sources wasn't high enough for my NEC 9PG+ (and switcher) to reliably sync to, so I can't comment on a comparison between picture quality with a standard scart cable. I did try making a DIY sync separator but couldn't get it to work. It seems even more expensive when my progscan DVD player only cost £50!
    Regards, Simon.
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I would go for the sync enhanced version CRT PJ's are very fussy.
    It's ony a £20 difference now. but it Could be £50 later :suicide:
  6. cosmic023
    cosmic023
    Feb 15, 2003
    1,369
    48
    Somerset
    +87
    Hi All,
    Cheers guy's for the info.........
    I knew CRT projectors can be fussy on what you feed them sometimes, that's why i asked.
    So that's settled then i'll order a syncblaster cable from keene asap !!
    Many thanks again.
    Cosmic023
  7. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Note to self - buy shares in Keene :)
