Keene Scart Commander - superb!
Discussion in 'Plasma TVs' started by Rob100, Jan 29, 2003.
  1. Rob100
    Rob100
    Nov 3, 2002
    3,469
    +227
    Hi all,
    Received my Scart Commander today and have to say it's superb. Upon release I initially purchased a BT945 Quintro, but on the whole I was dissapointed with this product and returned it to Keene who's service has been excellent and I paid the extra to upgrade.
    Problems/dislikes of BT945:
    1) Poor build quality - especially the scart sockets. I found that it was happy with cheapo cables, but good cables with metal scart plugs tended to fall out. When you put the plugs in the sockets the whole rear of the unit flexed.
    2) One audio channel on the laser disc input packed up after less than 24hrs use.
    3) Terrible audio quality. All audio channels sounded distorted, especially from the Sky box. Even after reducing audio level (as I thought the input was overloaded with the Sky boxes 2v op) there was noticable distortion in the audio.
    4) Audio delay. If it wasn't for the poor quality this may have been good thing (to compensate the plasma), but there was definately a delay between the audio going and in and what came out. To prove the point, if I routed one channel through the BT945 and one not you got almost a double beat when listing to music (e.g. MTV).
    5) Lack of ability to disable the auto scart switching (would have resulted in snipping wire 8 in scart cables).
    So far though I can't fault the Scart Commander. Build quality is great, as is audio (no distortion or delay) and PQ (only tried switching RGB to a JS RGB-VGA box). If anyone wants more info (or the manual for the Scart Commander) then download it here.
    Rob
  2. TheBigApple
    TheBigApple
    Dec 10, 2002
    664
    In my cage
    +13
    Thanks for the heads up, I was on the verge of buying the quintro, but won't bother if it's that bad.
  3. TheBigApple
    TheBigApple
    Dec 10, 2002
    664
    In my cage
    +13
    Just noticed in the specification.
    "2 control channels for AV system control (pin 8 for AV active and widescreen / normal, Pin 16 for RGB or not RGB selection) "
    Does this mean that only two of the four inputs will do auto switching?
  4. Rob100
    Rob100
    Nov 3, 2002
    3,469
    +227
    All 4 channels (AV inputs) certainly auto switched. I think they are saying that the status of both pin 8 and pin 16 are switched from the selected scart input to the scart output.
    Personally I hate the auto switching and I am so pleased you can switch it off.
    Maybe I was unlucky with the audio problem on my Quintro? I did think the recording facilities on it were good, but if it compromises quality then what's the point.
    Rob.
  5. Kevo
    Kevo
    Aug 23, 2001
    5,364
    Manchester
    +146
    Surely this thread should be in 'General Hardware' forum?
    And with a more descriptive Header like 'Quintro Review' would have helped.
    Then I (and others) would have read before purchasing :mad:
    Only stumbled upon it by chance!
    Thanks Rob100
  6. Rob100
    Rob100
    Nov 3, 2002
    3,469
    +227
    Hmm, maybe the wrong forum - but this is where I "hang out" and lack of conectivity is a major problem for most plasma owners.
    I was never meant to be a Quintro review, I was really just praising the Scart Commander, but it kinda developed from there!
    Rob
  7. Kevo
    Kevo
    Aug 23, 2001
    5,364
    Manchester
    +146
    Received my Quintro and I am well pleased with it.
    Must admit, I didn't experience ANY of the problems that Rob100 did (must have had a real duff one).
    Pic & sound are fine, no distortion.
    Auto detect works a treat.
    I use heavy IXOS SCART leads and they fit in fine, no probs.
    No audio delay, although there is some screen flicker (few secs) when you initially turn a device on, but after that it's ok.
    Well worth a look.
  8. Rob100
    Rob100
    Nov 3, 2002
    3,469
    +227
    Good to hear you are happy with it. Maybe I was unlucky...
  9. jpfrost
    jpfrost
    Jan 18, 2003
    93
    Anyone tried the Trilogy 1 from Lecktropacks?
  10. Kevo
    Kevo
    Aug 23, 2001
    5,364
    Manchester
    +146
    Isn't this the same as the B-Tech Quintro re-badged (and a LOT more expensive)?
    Although I don't know where the 'trilogy' bit comes in :confused:
  11. Mac1
    Mac1
    Sep 28, 2002
    49
    i got my quintro through this morning , all works fine except for one strange thing, when i select the tv input there is no sound everything else works, any ideas ?
  12. Kevo
    Kevo
    Aug 23, 2001
    5,364
    Manchester
    +146
    Selecting 'TV' simply puts your TV in 'tuner mode' and 'turns off' the Quintro. Don't know why you're not getting any sound.
    How have you got it all connected up?
  13. Mac1
    Mac1
    Sep 28, 2002
    49
    scart lead from tv to quintro, dvd, laserdisc, video and sky all in their respective sockets and playstation in the aux, quintro connected to amp via phonos from hi fi phono plugs
    I only listen to the tv through the amp so the tv volume is turned off, does the quintro not get the sound via the amp for the tv setting
  14. Kevo
    Kevo
    Aug 23, 2001
    5,364
    Manchester
    +146
    Don't think it does and would explain why you're not getting sound from your amp.
    'TV' I think means no input device. (not that obvious!)
    You may need to add your TV to one of the SCART/phono INPUTS from an OUTPUT from your TV.
    btw, I thought the aux wasn't rgb compatible. If so then you're better off putting your playstation on a different scart input.
    E-mail or PM me if you like.
  15. Mac1
    Mac1
    Sep 28, 2002
    49
    all sorted thanks for the help
  16. mca
    mca
    May 7, 2003
    274
    +34
    Hello all (just getting that out of the way as this is my first post).
    A quick question that hopefully someone will answer that has one of these units:
    Have any of you got the unit connected to a TV that has a 'smart' mode (that's what my Sony calls it) such that it will go into wide screen mode when it gets a wide screen signal?
    The reason I ask is that I bought a Trilogy 1 unit from Lektropacks and my TV would get a bit confussed and constantly change between smart and wide screen modes when a wide screen signal was being sent, either from my Sky/TiVo or my DVD player.
    I've since taken the unit back to Lektropacks who, after I queried what was happening, said that out of the several hundred units they'd sold I was the third to report the problem and they had no solution.
    The Trilogy unit looks identical to the one sold by Keene's & Beyond hi-fi but doesn't have the Qunitro name on it so might not actually be the same but I doubt it. This gives me hope that getting the b-tech version from these other places may give a working unit (& cheaper too :) ).
    My set-up in case it helps:
    Sony KV28FX20 TV
    Toshibe SD2109 DVD player
    TiVo
    Sky digital Pace box
  17. Kevo
    Kevo
    Aug 23, 2001
    5,364
    Manchester
    +146
    I have the Quintro version and have no WS switching problems.
  18. mca
    mca
    May 7, 2003
    274
    +34
    Thanks for the reply Kevo, out of interest what TV is that on? (just in case it's a problem with a certain brand of TV...)
  19. Kevo
    Kevo
    Aug 23, 2001
    5,364
    Manchester
    +146
    Toshiba.
    I used to have a Sony WS TV (old model) and I had many problems with WS switching, before I had the Quintro.
