Keene IR extender intermittent problems
Discussion in 'Home Cinema Control & Remote Controls' started by jasper_mccrea, Aug 2, 2005.
  1. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    923
    28
    London
    +25
    I got a Keene IR extender about a month and a half ago, and for the most part, it's pretty good. However, sometimes after a couple of days working OK, it just stops working. If I open up my cabinet, unplug and replug all the wands in the amp, it usually starts working again. Unfortunately last night this was not the case, no amount of fiddling could get it to work again. I ended up disconnecting the amp in frustration and just keeping my cabinet doors open.
    The amp is receiving a signal (the LED on the amp is flashing), but my kit just isn't getting the signal. Or it is, and it's muddled. I don't know.
    It's a pretty annoying problem. Anyone got any ideas as to cause and/or solution?
    Thanks,
    Jasper
